Chevrolet Colorado
Platform: GMT 350, GMT 31XX
Trailer brake controller needed?`
Old Dec 12, 2019 | 7:34 AM
Nick Willi's Avatar
Default Trailer brake controller needed?`
Greetings, all:
I recently purchased a 2018 Colorado to pull a 3500 lb camper trailer. The truck is equipped with the towing package and has the hitch and 7 point plug installed. From what I know, it looks to be good to go for towing.
Our previous tow vehicle did not originally come with the 7 point plug and it was installed along with a trailer brake controller under the dash in front. I never really used it for anything except looking at the numbers change.
Do I need to have a brake controller installed on the truck before I tow the camper? Doesn't one of the wires in the 7 point plug manage the trailer brakes?
Thanks for the advice!
Sincerely,
Nick
Old Dec 12, 2019 | 4:17 PM
if the truck isn't factory equipped with a brake controller...you will need one to power the electric brakes. consider getting a factory controller if its an option... as it incorporates sway control using the abs, yaw sensors already present with the stability control system. it will also fits into the knee bolster neatly. aftermarket controllers do not incorporate sway control.
Old Dec 13, 2019 | 7:37 AM
Nicholas Willi's Avatar
Thank you very much for the information. That's what I was looking for. I've seen the aftermarket controllers but found this factory controller: https://www.gmpartsstore.com/oem-par...662?origin=pla
According to the page, it fits the 2015 - 2019 Chevy Colorado, except for 2018 and that seems weird to me. I'll keep looking or do you have a suggestion?
Thanks again!
Old Dec 13, 2019 | 8:34 AM
that is not a factory controller. Its made by curt.
call the dealer parts dept. and get a quote. maybe factory controller are not an option for a Colorado.
Old Dec 29, 2019 | 7:12 AM
rmclin's Avatar
Default Factory brake controller
I have a 2018 with a factory electric brake controller. I might be wrong but it's my understanding that a factory unit cannot be retrofitted since the wiring is not installed unless the truck came with the brake controller from the factory. An aftermarket unit would work but as noted the anti-sway would not be available.
Old Dec 29, 2019 | 11:36 AM
It may be a dealer install accessory. Gm parts would know. I have done them on the 1500's. It comes with a controller, wiring harness and then must be dealer programmed.
Jason J Phillips
Colorado
Jul 17, 2018 2:12 PM
humnbass
May 29, 2015 10:39 PM
Tryg
Nov 29, 2011 9:32 PM
Kevllaar
Nov 29, 2009 8:03 PM
Caniac
Aug 26, 2009 7:53 AM
