Corvette Since 1953, the All American Sports car, and with the new 2014 C7 model, no end is in sight.
2014 Corvette C7
Platform: Y-body
Latest Corvette C7 News here: CorvetteForum.com
Car overheating problem for a 1995 corvette!!! Help! Please
Old Jan 9, 2014 | 12:12 PM
dandeluxe's Avatar
Default Car overheating problem for a 1995 corvette!!! Help! Please
When running w/ the air off, neither fans run, causing the motor to overheat. with the air on, both fans run, and the temp is normal. fuses is good, i have taken the car to 2 places, neither can find the problem. 1 place says he is studying the schematics, but no luck. i know the car has 2 temp sending units, could one of these be bad? weather is so f--king bad the i am not planing to move the car till spring(if you live close to chicago you will know what i mean)!! can anyone help, has anyone had this problem before?
thanks
Old Jan 11, 2014 | 11:52 AM
Catbert's Avatar
Define overheat. Does it lose water/coolant? How hot does it get?
Old Jan 17, 2014 | 11:38 PM
sledge.impy's Avatar
thanks
Is this an LT1 and not an LT5?
Are you 100% SURE both fans are running with AC on?
Have you verified the relays are running properly?
Where does the temp gauge go to when 'over heating'? 210? 235?
Boil over?
I can't imagine being in chicago polar vortex's that idling would over heat after a long time.
AC should kick on both fans all the time...
Lifted 02 z71 Tahoe
Apr 28, 2015 7:00 AM
thesoccer4
Jan 17, 2015 10:10 AM
dellis
Dec 29, 2011 9:37 AM
phillipsj
Mar 11, 2011 12:48 AM
mrrish2010
Astro
Nov 7, 2010 9:56 PM
