Car overheating problem for a 1995 corvette!!! Help! Please
When running w/ the air off, neither fans run, causing the motor to overheat. with the air on, both fans run, and the temp is normal. fuses is good, i have taken the car to 2 places, neither can find the problem. 1 place says he is studying the schematics, but no luck. i know the car has 2 temp sending units, could one of these be bad? weather is so f--king bad the i am not planing to move the car till spring(if you live close to chicago you will know what i mean)!! can anyone help, has anyone had this problem before?
thanks
thanks
thanks
thanks
Are you 100% SURE both fans are running with AC on?
Have you verified the relays are running properly?
Where does the temp gauge go to when 'over heating'? 210? 235?
Boil over?
I can't imagine being in chicago polar vortex's that idling would over heat after a long time.
AC should kick on both fans all the time...
Lifted 02 z71 Tahoe
April 28th, 2015 7:00 AM
dellis
Silverado & Fullsize Pick-ups
December 29th, 2011 9:37 AM
phillipsj
March 11th, 2011 12:48 AM
