Corvette Since 1953, the All American Sports car, and with the new 2014 C7 model, no end is in sight.
2014 Corvette C7
Platform: Y-body
Latest Corvette C7 News here: CorvetteForum.com
Electrical Problem
Old Nov 23, 2009 | 11:21 AM
Michael Dowd's Avatar
Default Electrical Problem
I have been trouble shooting a problem that I thought was fuel related and found out the immediate problem is electrical. The car will still not run past and idle cold and not at all once warm but when I was trying to determine a cause I disconnected the plug on the alternator and the stalling problem went away, plugged it back in and it came right back. I also reconnected the alternator and disconnected the battery while still running and it went away. All of the connections seem to be good and the battery tested out fine and is holding a charge. The alternator is new/rebuilt and the battery is several years old but seems to be OK.
Any suggestions?
Thank you for any feedback you can provide.
Old Nov 27, 2009 | 11:40 PM
What year? Make sure battery ground to frame, engine ground to frame are good.
Old Nov 30, 2009 | 11:33 AM
The Corvette is a 1990.
I will check the grounds to the frame and to the engine.
Thank you for the hints.
Old Dec 3, 2009 | 4:37 PM
You might also post over in out sister forum at corvetteforums.com.
Old Mar 2, 2010 | 3:50 AM
f-bodyfreak's Avatar
id say theres a short in the alt even thow it was just rebuilt iv seen them turn into magnets and my wrenches stick to them and them get real hot and there right out of the box rebuilt
jlawson435
Nov 5, 2013 5:54 AM
phmiller
Apr 27, 2010 7:08 AM
peros
Jan 24, 2006 9:50 PM
Spydertek
Jul 13, 2005 5:44 PM
