Electrical Problem
I have been trouble shooting a problem that I thought was fuel related and found out the immediate problem is electrical. The car will still not run past and idle cold and not at all once warm but when I was trying to determine a cause I disconnected the plug on the alternator and the stalling problem went away, plugged it back in and it came right back. I also reconnected the alternator and disconnected the battery while still running and it went away. All of the connections seem to be good and the battery tested out fine and is holding a charge. The alternator is new/rebuilt and the battery is several years old but seems to be OK.
Any suggestions?
Thank you for any feedback you can provide.
Any suggestions?
