Chevrolet Cruze
Also Check out CruzeChat.com
2011 Cruze not starting
Old Jul 26, 2024 | 1:10 PM
TreenyCakes's Avatar
Default 2011 Cruze not starting
I bought a 2011 Cruze 1.4 cylinder with almost 156,000 miles in march. In the past when I’m on the turnpike with cruise control set at 80-85 mph it would struggle with the repetitive hills I was driving up and down so cruise control would punch the gas and my rpm’s would go up and my overheat, idle engine and usually stabilitrak warning wld sound and I wld slow down significantly and the warning would stop and I stopped using cruise control. Well the other night I failed to stop cruise control before starting the multiple small inclines and when I noticed the rpm’s I immediately cut it off to drop the rpm’s and after I received 3 different overheat warnings. The first said a/c off due to engine temp (I did not hv my a/c on to begin with), the overheat idle engine and a coolant too hot warning. I pulled over and idled for a second until I noticed the temp gage was all the way to the right and I cut off the engine. All the coolant was gone and u added 3 bottles of water I managed to get and tried starting it after the warnings all stopped and it tries to start but won’t. I had it towed and discovered a radiator hose was torn and had it replaced. Now when I turn the key the display says “reduced engine power, service stabilitrak, service traction control” and it still tries to start but won’t. What could be the issue? Thank you!!!
Derrick71
May 4, 2024 4:26 PM
Khall35
Cruze
Mar 28, 2022 12:06 AM
Patty Nickels
Cruze
Oct 18, 2021 2:17 PM
Megan Trautman
Jul 3, 2016 5:14 AM
