Chevrolet Cruze
Also Check out CruzeChat.com
2014 Chevy Cruz - I believe electrical issue??
Old Jul 28, 2024 | 4:27 PM
Steve0529's Avatar
Default 2014 Chevy Cruz - I believe electrical issue??
So i'm having all kinds of weird issues with my Cruz that I believe may be inter related to a possible electrical issue, maybe alternator?
I have attached a video with a noise that the car is making. It seems to happen after the car has run for a few minutes and I've also noted that when driving if I accelerate the noise will go away until i back off the accelerator and it comes back.
A couple other things have started happening right around the same time:
1. When the car is put in park the motor will rev up to about 3k-3.5k RPMS and then slowly back off.
2. Randomly the temp gauge will shoot up to the point that I get a message that the AC has been shut off because of engine heat OR it will shoot all the way up and I'll get a stop engine message. I know the car is not overheating as there are no other signs of it overheating AND the temp gauge will generally come back to normal and everything will be fine.
Things i've done since this all started and the issues still persist.
I did have a code for the Mass Airflow Sensor (seems to be a default code for everything these days)
tried cleaning then changed Sensor
changed valve cover gasket
changed plugs
changed serpentine belt
Thanks in advance for any help, this is driving me crazy,
File Type: mov
nbishop401
Dec 22, 2023 7:49 AM
kobaltic
Sonic (Aveo)
Mar 14, 2023 7:53 PM
Bryan Harvey
Apr 27, 2019 10:20 AM
Roccmann
Feb 21, 2015 8:09 AM
redequinox
May 22, 2013 5:46 PM
