Chevrolet Cruze
Also Check out CruzeChat.com
2012 Chevy Cruze MAF and Thermostat Housing Problem?
Old Apr 17, 2023 | 3:18 PM
Gali's Avatar
Default 2012 Chevy Cruze MAF and Thermostat Housing Problem?
Hey gang, first time poster here.
I've got a confusing problem. I've got a 2012 Cruze that's around 130K miles at this point, and I've been dealing with issues like a rough idle, failing emissions checks, and occasional jerking or stuttering when accelerating up to highway speed.
Overheating was also an issue, but I believe that problem to be fixed. It's been months of vigilant watch on my engine temp and no problem since.
The Firestone guys replaced the knock sensor and did other unrelated maintenance, and I replaced the MAF sensor and thermostat housing myself at their recommendation (it was a P1101 code).
Took the car in to be inspected before and after I replaced those parts, and they're still getting a P1101 code, again recommending replacing the MAF and thermostat housing (quoted at $300+ ).
Since they told me I installed the parts correctly, I find it difficult to believe both parts are faulty, so the issue must be something else entirely.
My knowledge of mechanics is very limited, apologies for not having more detailed info.
Anyone got any advice or ideas on what to check next? If I can fix it myself, I'd prefer that since I don't think another shop visit is financially feasible for a while.
Old Apr 17, 2023 | 11:41 PM
oilcanhenry's Avatar
Probably a PCV valve issue which may involve the replacement of the valve cover to solve the P11011 code on your Chevy Cruze.It's quite commonplace on the first generation Chevy Cruze.
Old Apr 26, 2023 | 5:27 AM
Originally Posted by juliann
did you talk to the dealer about this ?
No, I dont do dealerships at all. They are expensive rat-****ks
I know my mechanical tech. If need a tech, I'll use an ASE shop.
David White
Cruze
Feb 25, 2020 12:14 PM
Robin Hamilton
Cruze
Jul 26, 2019 3:52 AM
Kwathen88
Cruze
Feb 10, 2015 3:19 PM
Jennifer7286
Cruze
Oct 15, 2014 3:16 PM
