Chevrolet Cruze
Also Check out CruzeChat.com
2016 Cruze LT P0304 and StabiliTrak
Old May 13, 2024 | 4:36 PM
caedonbowes's Avatar
Default 2016 Cruze LT P0304 and StabiliTrak
The past month, I have been struggling with the check engine light as well as the StabiliTrak system. The car normally runs fine unless I get anywhere above 3kish RPM, which leads to the engine stuttering, the check engine light flashing, and the StabilitTrak light coming on. The engine light will flash for about 30 seconds and either switch on constantly or cut off. The StabiliTrak light will stay on until I turn the car off. I scanned for codes and it threw a P0304 code. Pretty weird as I just recently replaced the spark plugs and coil pack. I assume this could be a fuel injector issue, but I'm not sure.
The car will also run rough at idle. Not every time, but on occasion. I've also checked the throttle body and gas pedal, which both seem fine. Has anybody faced similar issues or have any ideas on a fix? Thanks.
Old May 13, 2024 | 8:29 PM
when the light flashes at you it's saying "stop driving immediately. You're causing damage"
You need to fix your misfire ASAP. There are many , many causes. You need to perform some troubleshooting and diagnostics to get you in the right direction. Check fuel trims. visually confirm good spark, etc. You can try swapping injectors with a good cylinder.
How many miles on it?
Patty Nickels
Cruze
Oct 18, 2021 2:17 PM
broke dwn
Sep 5, 2018 10:45 AM
dmjv21187
Jan 15, 2018 10:41 AM
Genadiy Portnoy
Nov 28, 2017 10:10 AM
Grumpkins
Feb 10, 2015 8:32 AM
