Chevrolet Cruze
Also Check out CruzeChat.com
P0300
Old Jun 16, 2024 | 11:18 AM
Mike Clark's Avatar
Default P0300
I'm getting a p0300 code on my 2011Chevy Cruze. 1.8L manual transmission. The data shows mis fires on cylinders 1&4 ~ 20 on each. I replaced the coil pack May of last year, GM part. Along with the CEL the stabilitrac and traction control light is on. I also have an intermittent issue of crank no start when the car is warm. The car will normally start after I pull the ecm fuse for about 30 seconds. I have checked and cleaned all the chassis ground terminals and I added a 2ga ground between the engine and battery. Any help or ideas would be appreciated. I replaced the plugs about a year ago and I checked them yesterday and they look good other than there was a little soot. The car has 130k miles an is used about 20-30k a year.
unbobfinch
Cobalt
Feb 13, 2023 1:52 PM
derrekcrews
Cruze
Dec 15, 2021 10:11 AM
gr3go
Cruze
Feb 20, 2018 2:20 AM
OtherCarASaab
Nov 5, 2012 7:43 AM
joejfsdc
Oct 14, 2010 7:41 PM
