Chevrolet Cruze
Also Check out CruzeChat.com
Code p0449
Old Nov 22, 2020 | 9:52 PM
Robertwilson's Avatar
Default Code p0449
I have a p0449 code reading on my check engine light. I have replaced evap canister, evap purge valve, plug connector on canister solenoid, and gas cap. Check engine light is still on. Any suggestion?
Old Nov 23, 2020 | 11:06 AM
what year and engine
Old Nov 23, 2020 | 4:45 PM
it is a 2015. It is an RS model. Not sure of engine specs.
Old Nov 23, 2020 | 8:50 PM
the code is for an open in the vent valve control circuit
so if the cannister came with a new vent valve...you need to check for power to the vent valve. with key on remove the vent solenoid connector..oneof the wires should have battery voltage. if it doesn't check the f4ua fuse in the underhood fuse block. if the fuse is good the wiring is open.
couchmusician
May 19, 2020 4:30 PM
telli101
Jul 25, 2019 5:24 PM
jamair
Apr 5, 2014 2:28 AM
chevygirl47
May 10, 2012 7:50 PM
soxfan81
May 25, 2007 8:31 PM
