Chevrolet Cruze
Also Check out CruzeChat.com
Coolant Fan
Old Sep 28, 2020 | 8:56 PM
  #11
chevyboy@22's Avatar
Default Chevy Cruze coolant fan
If the sensor isn't working, your fan won't turn onbecause it won't know that the temperature is hot enough to require activation, which can frequently lead to overheating.
Old Nov 24, 2020 | 8:45 PM
  #12
Ferdie Fern's Avatar
Like Jamal360 mentioned, it may be the temp sensor in the rad. After an overnight cool down with a scanner check the temperature readings from the rad temperature, engine temperature and intake temperature. They should all agree within 1 degree. If one of them is skewed you have to correct that. As for the A/C, it will not cycle on if there are any cooling system problems.
Lynton
Cruze
Oct 31, 2018 8:30 AM
edsproblems
Cruze
Feb 1, 2018 4:23 PM
dominion126
Jun 1, 2016 10:27 PM
xboxxer
Uplander
Dec 1, 2014 9:31 PM
ruffrider285
Sep 5, 2012 12:08 AM
