Chevrolet Cruze
Also Check out CruzeChat.com
Express Open not working
Old Aug 23, 2020 | 2:51 PM
Jsunnb's Avatar
Default Express Close not working
I have a 2018 Chevy Cruze Hatchback. All four windows have the express open feature. When I look at the users manual, it has instructions on how to enable to express close feature too, but every time I try it I am never able to do it. Just wanted to make sure I'm doing it right.
Manual Instructions:
1. Close all doors.
2. Turn the ignition on or to ACC/ACCESSORY.
3. Partially open the window to be programmed. Then close it and continue to pull the switch briefly after the window has fully closed.
4. Open the window and continue to press the switch briefly after the window has fully opened.
I have a push to start ignition, so I'm assuming accessory on is enabled by just pushing the button without pressing the brake. (but I've also tried it with the car on)
Nothing I've done works. 2 seconds, 5 seconds, 10 seconds. I've read some forums that don't include the partial open, tried just down, hold, up hold. nothing at all seems to work. Is there a trick I'm missing, or something special I need to check?
MiragePilot
Jul 1, 2019 11:28 PM
Minuteman
Jun 13, 2017 4:59 PM
destinpeters
May 25, 2015 2:17 AM
FurKids
Dec 6, 2012 12:49 PM
Luca1
Aug 11, 2007 9:25 PM
