Chevrolet Cruze
Also Check out CruzeChat.com
fan running
Old May 20, 2019 | 11:58 AM
Mtascher's Avatar
Default fan running
I just bought a 12 chevy cruze with only 34,000 miles on it. I was excited as i have never owned a car so new. I knew there was no warranty on it but seeing how it was taken great care of and so low miles i was hoping to own it for more then a month before having to repair it!!!! I have read up and replaced the Coolant temp sensor after reviewing the problem i was having and researching it. The problem is still there my check engine light is still on and the fan is still running constantly while the car is on, but not overheating. Any suggestions?
** P0597
Old May 20, 2019 | 1:43 PM
kevinkpk's Avatar
Post the code, is your ac switched to on?
Old May 20, 2019 | 2:05 PM
Mtascher's Avatar
code I believe was p0579 but when i look that up it shows a cruise control issue and I dont have cruise control in my car. Maybe i am wrong on the code. I have only run the A/C 2 times as it hasnt been warm enough to
Old May 20, 2019 | 4:45 PM
kevinkpk's Avatar
The fan will run if the ac is switched on, or if it thinks it is.
Old May 21, 2019 | 2:48 PM
Mtascher's Avatar
The code is P0597 the A/C is not on and the fan is running constantly. I have just learned there are 2 different temp sensors. I will try and replace the other one and hope for the best
