Chevrolet Cruze
Also Check out CruzeChat.com
Fan runs non-stop
Old Aug 20, 2017 | 9:32 PM
Geno4435's Avatar
Newly Registered
Default Fan runs non-stop
2012 Chevy Cruze LT 1.4
All of the sudden the fan would not cut off runs continuously, I had to disconnect the negative cable to shut off (was concerned about draining the battery overnight) what could be the cause? No MIL or DTC
Old Aug 21, 2017 | 10:59 AM
What does the temperature gauge read? Is it normal? It could be a bad relay.
Old Feb 1, 2018 | 4:22 PM
jmssimms75's Avatar
This is a common problem....i surmise that if you had the codes checked, you would get P0597/P0598--has everything to do with chevy switching to a thermal housing instead of a simple thermostat. If you look online for that code you will see a lot of chevy's are having problems with this. I'm currently having this problem and "patiently" waiting for some Chevy Rep to actually contact me. I have to pass a emissions test for my Chevy this month, but I can't pass while experiencing these codes.
