Chevrolet Cruze
Also Check out CruzeChat.com
Heat Won't Turn Off!!
Old Feb 14, 2018 | 12:12 PM
Prairie1907's Avatar
Default Heat Won't Turn Off!!
No matter where my temp setting is my vents are blowing hot air. Even turned my a/c on and it's still blowing hot air.
HELP ME!!!!!!!
Also....my defrost fan won't engage. All air is coming out front vents. Can' defrost my front wi ndshield
Old Feb 15, 2018 | 8:27 AM
you will need a full function scan tool to check for codes set in the hvac module. this is the computer that controls temp and mode door functions.
the computer controls the movement of actuators that move the temp blend and airflow mode doors. did both problems happen at the same time?
Old Feb 15, 2018 | 8:39 AM
I noticed the front windshield defrost not working about 2 weeks ago but only noticed the heat issue yesterday.
