Chevrolet Cruze
Also Check out CruzeChat.com
Hot air from the center console by drivers legs
Old Apr 8, 2014 | 10:19 PM
dr.zeus's Avatar
Default Hot air from the center console by drivers legs
In my 2011 Cruze i have very hot air entering the drivers leg area. If the AC is on then the vents will blow cold air, but super heated air is still coming from down below in this location. If the AC is on low then only small amounts of hot air come out of this spot, but if the AC is on high then as well as large amounts of cold air coming out of the vents, large amounts of hot air come from this spot. It seems to be coming from the center console area right under the dash to the right of the steering column down by my right knee. I pulled the panel off of the console by my right knee to expose the area in question and reveal a metal box with too metal tubes going into it. The tubes are very very hot and so is the metal box. What is this box? The hot air appears to be coming from the very top of the box where there seems to be a little gap/space along the top of it. The box seems to be kind of loose and i can see how to remove it from its current location. If i push up on it so this gap is smaller then the hot air flow seems to reduce somewhat. What is casuing this? Is the heat coming from that metal box? Is it coming from some other component close by? It is a very uncomfortable issue and it is starting to heat up enough outside to make a difference again.
This car has been in the shop for lots of problems, the worst being an antifreeze leak that caused a total rebuild of the cooling system. I feel like they probably didnt put something back together right at that time since they told me they had to remove the dash. They are very little help in my chevy dealership/shop. I have lost faith in them and hope to correct this myself. Any help would be greatly appreciated.
Attached Thumbnails Hot air from the center console by drivers legs-imag0057.jpg   Hot air from the center console by drivers legs-imag0060.jpg   Hot air from the center console by drivers legs-imag0058.jpg
Old Jul 27, 2015 | 12:30 AM
wayne0no's Avatar
Did you ever resolve this issue I'm having the same problem with my 2014 really hot air blowing on my right leg
Sorry for posting on such a old post just the only one i have found with the same problem and thank you in advance
AnnaRiling
Oct 3, 2023 12:24 PM
Danistheman1234
May 18, 2011 10:49 PM
Danistheman1234
May 14, 2011 8:55 PM
larryboy58
May 23, 2010 5:50 PM
chevy04z71
Sep 24, 2009 7:32 PM
