Chevrolet Cruze
Also Check out CruzeChat.com
Problem with chevrolet cruze 2009 1.8 ls
Old Dec 20, 2023 | 1:41 AM
Loren12's Avatar
Default Problem with chevrolet cruze 2009 1.8 ls
Hi i have 2009 chevy cruze. I have a problem that it is jerking at low rpm. I have replaced basically everything new on the car. Like new coilpack, new petrol pump. New throttle body, new tappet cover, new oilpump, new water pump. New thermostat. New timing tensioner.
Im basically up in arms dont know what anymore. I also cleaned the catalytic converter. Still it stutter at low rpm.
Any one that might have any solution. Im from Cape town South Africa. Please if you can advise.
Regards
Loren
Old Dec 20, 2023 | 7:13 AM
Charles Martin54's Avatar
Hey Loren, Here's a curveball for you – have you checked your engine mounts? If they're torn or even just a bit weary, they can make your engine dance around more than it should. This can cause that jerky feeling at low RPMs you're talking about. It's an often overlooked spot, but it could be the sneaky culprit behind your troubles. Give it a shot and see if it smooths things out.
Old Dec 20, 2023 | 7:45 AM
Loren12's Avatar
Default Problem chevrolet cruze
Thanks for advice. Will definately look at it.
Old Dec 20, 2023 | 12:59 PM
You're welcome! I'm eager to hear back from you with an update – let me know how it goes
Tireguy 94
Cruze
Oct 8, 2023 1:21 AM
CruzeDiesel
Cruze
Jul 31, 2013 2:44 PM
crashhat69
Cruze
14
Dec 4, 2012 7:12 PM
piyush1
Cruze
Nov 9, 2011 2:27 PM
