Chevrolet Cruze
Also Check out CruzeChat.com
The radiator cooling fan is running with engine shut off and keys off ignition switch
Old Jun 8, 2017 | 10:49 AM
LenRod's Avatar
Default The radiator cooling fan is running with engine shut off and keys off ignition switch
2014 Chevy Cruze. The radiator cooling fan started to keep blowing non-stop even when the engine is shut off and keys are off ignition. I contacted the dealer at Buena Park and they want to charge me $100 for just a diagnostic. Shouldn't this be a recall issue? I also have extended service coverage. Shouldn't this be covered under my extended service under 75000 miles?
Old Jun 9, 2017 | 7:36 AM
Is your extended service for everything or just the drive train? Your problem is probably a temperature sensor and should be covered under the extended if your coverage is for everything. Is your extended coverage from Chevrolet or another company?
