Engine Building & Overhauling All you ever wanted to know about building and rebuilding engines in here! Remember to post your model-specific questions in the correct section.
383 Stroker
Old June 21st, 2009, 3:29 PM
Big Baby 78's Avatar
Default 383 Stroker
This is my first build just curious on what kind of numbers can i produce with this combonation of products(1992 stock block 2pc rms 4 bolt, eagle stroker rotating assembly 5.7 rods kb hyp flat pistons, procomp 195 64cc heads, comp mag 280/230 cam hyd flat, eld performer rpm intake, 750 holley vac sec carb, msd 6al ignition system, comp mag 1.5 rockers just to name a few going in a 85 shortbox chevy c-10. tranny 350th w/t 3500 stall stock rear end. any feed back would be appreciated.
xx76scorpsxx
Silverado & Fullsize Pick-ups
January 27th, 2016 9:53 PM
vhrocker
Corvette
13
September 28th, 2012 5:08 AM
srv748wg
May 21st, 2007 7:46 PM
weltzm1
February 14th, 2007 2:31 AM
Quick Reply: 383 Stroker
