Engine Building & Overhauling All you ever wanted to know about building and rebuilding engines in here! Remember to post your model-specific questions in the correct section.
383 Stroker
Old January 25th, 2018, 8:12 PM
Boozer74's Avatar
Default 383 Stroker
I am wanting to build a 383 stroker. I have some building experience but only some. Enough to build an engine.
I am building this engine for dirt track racing.
I have a 2 piece RMS. 2 bolt Main. I am looking for torque and want the power band around 4000 to 5000 rpm. I will be running late model tires ( 12 to 13 inches wide).
What 383 kit would be recommended ( scat- eagle- etc. )
i have a set of 882 heads and a set of vortex heads with z28 springs. I have aluminum intakes or steel.
Holley 4412 carb 500 cfm
i have no idea what cam to run or what lift will fit. Just looking for some advise.
Old January 26th, 2018, 7:20 AM
oilcanhenry's Avatar
Crane cams are the best IMO.
Old June 10th, 2018, 10:33 PM
1986-isuzu-pup's Avatar
Default 383 stroker
How hard would it be to put a 383 stroker in a 2005 Chevrolet Silverado with the 5.3 in it?
Old June 14th, 2022, 1:18 AM
Savag3Cookie's Avatar
Default My 383 won't stay running
My 383 I can't get to idle it will start up with starting food but as soon as the starting food Burns off it dies I'm getting fuel i can see it pumping in there when i have a key on and i pump the gas but it still won't start or stay idling only with the starting fluid.
Any suggestions?
Ryan Joseph Azevedo
December 6th, 2018 10:15 PM
Deh_KOKaRoach_56
October 16th, 2012 7:30 PM
Stubbs
January 4th, 2012 10:44 PM
383Chev
July 29th, 2008 3:30 AM
77camaro
February 12th, 2007 1:14 AM
Quick Reply: 383 Stroker
