Engine Building & Overhauling All you ever wanted to know about building and rebuilding engines in here! Remember to post your model-specific questions in the correct section.
454 questions
Old June 30th, 2012, 6:25 PM
godtar's Avatar
Default 454 questions
AS you see the heads (78 454) have cooling passages front center and back. Why do aftermarket manifolds NOT have these passages,, they seal them off. I have seen some with tapped pipe fittings on the rear that corresponding to the rear passages. Does it not overheat?
Where is the best spot to tap oil pressure port on the block
Thanks,
doug
Old June 30th, 2012, 7:43 PM
kevinkpk's Avatar
Thanks,
doug
Youre going to have to deal with specifics, such as date ect. The head match should just go with head gasket as (ex) x head on a 454 block. Heads vrs. block, thats what you have to do, big block chevy with ?? head match up.
Troll_in_the_Dungeon
March 9th, 2015 3:00 AM
core shift lsx 454
November 18th, 2012 3:35 PM
heavychevy511
Silverado & Fullsize Pick-ups
October 31st, 2012 8:43 PM
woodstockaz
August 15th, 2010 4:08 PM
rogerwood
Computer, Ignition, & Fuel Systems
November 17th, 2006 12:17 AM
Quick Reply: 454 questions
