Engine Building & Overhauling All you ever wanted to know about building and rebuilding engines in here! Remember to post your model-specific questions in the correct section.
Help me settle this debate
Old January 6th, 2007, 9:09 PM
raven14058's Avatar
Default Help me settle this debate
My friends and I having a bit of an argument.
I say that a 383 chevy is a bored out 350 (.30) with a 400 crank
They say that a 383 chevy is a 350 with a 400 crank and 400 heads.
Who is right here?
Old January 29th, 2007, 3:16 AM
highperf4x4's Avatar
Default RE: Help me settle this debate
You'd be correct. Heads have nothing to do with Cubic Inches on any engine. Cubic Inch Displacement is a measure of the "size" of the piston and how far it travels from top dead center to bottom dead center. This is the "volume" of air/fuel displacement.
Heads will have an affect on the "compression" ratio depending on the size of the combustion chamber. Stock 400 SB heads all have large combustion chambers meaning "lower" compression ratios which amounts to less power.
If your friends disagree, then build your engine and let them build theirs and wager as much money as you can on the first race.
kenney
January 31st, 2009 5:29 PM
jharper
December 11th, 2007 4:15 PM
raven14058
January 7th, 2007 2:07 AM
Quick Reply: Help me settle this debate
