hesitation
hesitation
Every time i stomp the pedal through the floor, the car hesitates a second, then goes. it is a freshly rebuilt 350 with quote "the best quadrajet the engine builder has ever seen" is there something that would cause this? or do i just have to live with it? if i roll into the throttle slowly it has no hesitation, only if i mash it down, but it is a racecar, so i have to mash it.
RE: hesitation
TOO MUCH FUEL
The engine is getting to much fuel or not enough air as EuroGoldLs said and I an not sure about the adjustments on your carb so you might be able to fix it or it might be something you will have to live with
hopkinstx
Express & G-Series Vans
September 17th, 2006 12:29 AM
bradstump
Silverado & Fullsize Pick-ups
12
September 4th, 2006 2:05 AM
