2008 Equinox door problems
#12
I wonder if one of the actuators is shorting out and causing the relays for the locks to act up. There are three relays (unlock/lock/driver unlock) built into I/P fuse panel according to the diagram.
I would definitely would not rule out broken wires in one of the front door jambs.
Equinox_Door_lock_wiring_diagram.pdf
#14
there are threads on here with pics of where to inspect. maybe a search would help you out. Was the wiring broken or not; you seem unsure?
#15
Equinox Power Door Locks
I have a 2008 equinox with the same problem. The locks work intermittently from the FOB and the button on the door doesn't work at all. It started on the drivers door and spread to the others. Post I have found indicate there are two relays, one for the front doors and one for the rear doors. I think the relays are located somewhere in the center console, but the access to them is very bad. I can hear the relays trying to actuate, but I can't access them. Do you know what the procedure is for getting at these relays to replace them. This seems to be a good way to start due to the expensive door actuators (~$140 per door(.
#16
You could disconnect each door lock actuator and temporarily run power & ground directly to them to test them. Be sure to also reverse the polarity of your power & ground connections to make sure they work both ways (lock/unlock).
You should first and foremost inspect the wiring in both front door jambs if you haven't done so already.
Amanda King (April 23rd, 2021)
#18
Official GM Rep
Amber N.
Chevrolet Customer Care
#19
Both passenger locks won't work
Both of the passenger side doors have gotten to where they will only lock & unlock manually. Occasionally in the winter time they MAY work, but usually only half way. I believe this is a manufacturer defect because I have seen dozens of the same complaints. I'm sure it's the actuators, but they are expensive to repair. I worry about them not locking when I put the car in drive because stopping at red lights can be dangerous. I'm afraid someone will walk up & get in the car, because the doors won't lock. Please offer some kind of assistance with this repair....as SO many people have the same issue.
#20
Annoyed as well
