Aftermarket subs on an 06 equinox?
I read somewhere that on certain chevy models you can attach a Line-Output converter to the factory amp in order to set up an aftermarket sub setup using the factory sound system but wasnt sure if it would work on the 'Nox. Is this possible? and where would i find the harness to make everything work like it should?
Ryno
Silverado & Fullsize Pick-ups
August 16th, 2012 6:26 AM
zoey
September 22nd, 2006 3:07 PM
