Equinox This SUV offers a smaller, sportier stance than the Trailblazer, all without compromising the SUV abilities.
Chevrolet Equinox
Platform: Theta
Big Cooling Fan - Won't Start
Old July 24th, 2012, 7:14 AM
kbro's Avatar
Default Big Cooling Fan - Won't Start
I have a Equinox 2006 and the big cooiling fan (the one on the driver side) won't start. I checked the fuses / relay and nothing. I replaced the fan motor and the problem continues. Also the mechanic checked that current is flowing to the motor. Anyone have experienced this issue?
Old July 24th, 2012, 11:39 AM
You have a new motor and there is 12 volts going to it and it doesn't run. No something is wrong. Either there is not 12 volts going to it or you got a defective new motor. This is easily checked with a volt/ohm meter. Check the line to the motor yourself with the meter to see if it is getting 12 volts. You can ohm out the motor to check if it is good.
63c10guy
November 20th, 2011 7:27 PM
obby121
Silverado & Fullsize Pick-ups
February 12th, 2011 1:29 PM
stephonline15
April 26th, 2008 3:36 PM
ottawaventure
August 13th, 2006 12:26 AM
xswinnyx
May 13th, 2006 1:01 PM
Quick Reply: Big Cooling Fan - Won't Start
