engine stall on acceleration-no codes
Newly Registered
2016 Equinox
Intermittent stalling when accelerating. Check engine light not on. Took to mechanic and they found no codes except for P0010, "Intake camshaft position actuator solenoid valve control circuit-Pending." Sometimes stalls with or without A/C on. Put HEET in gas to make sure no water in tank. Added injector cleaner. Stalling still occurs. Mechanic drove SUV and could not duplicate problem. Mechanic says he can replace the part shown in the "pending" error code, but can't guarantee that's the problem as it could be caused by multiple things.
Has anyone had this problem and were you able to fix it?
