Cobalt This sporty compact was faced with the difficult job of replacing the popular Cavalier, but whether the base model, or the supercharged SS is chosen, is has made for a great replacement.
Platform: Delta
Also Check out CobaltSS.net
Need help!! CEL codes
Old Oct 23, 2011 | 10:16 PM
yellowss's Avatar
Default Need help!! CEL codes
Hey guys,
I have a 2006 cobalt SS with 2.4L. I have 2 engine codes that came up and i don't know what to do with them. I purchased a new cam position sensor and tried to place it on the intake side then erased the code... code came back so i put it on the exhaust side and erased it.. code is still there and i dont know what to do anymore. has anyone ever had this problem in relation to these to codes? and what should I do?
P0366 Camshaft Position Sensor "B" Circuit Range/Performance Bank 1
P0010 camshaft position actuator circuit
Thanks
Mitch
Old Oct 23, 2011 | 11:58 PM
EinST's Avatar
Welcome to the forum. P0366 means exhaust CMP sensor performance problem, i.e., an incorrect number of CMP sensor pulses detected. P0010, on the other hand, means intake camshaft position actuator solenoid valve control circuit problem, electrical in nature. I don't really see a connection between the two. Unless you're very lucky, throwing parts at the problem isn't going to solve it. Consider taking it in for service, any GM dealership.
BrianL
Sonic (Aveo)
Feb 18, 2020 5:42 PM
04YukonAWD
Mar 8, 2015 1:37 PM
aubiexx
Nov 26, 2012 7:29 PM
Tashier
13
Mar 24, 2012 3:48 PM
redhotneon
Apr 16, 2007 10:31 AM
