Equinox This SUV offers a smaller, sportier stance than the Trailblazer, all without compromising the SUV abilities.
Chevrolet Equinox
Platform: Theta
Key stuck, no power.
Old November 17th, 2013, 7:01 AM
  #11
tomwalt's Avatar
Originally Posted by Pknuts85
Hi Amber, I only bought my equinox 4 days ago 2007. What would you recommend that I do now? I am having same problems as Jimmie. Reduced engine power , key got stuck, back wipers won't work.
Please advise !
Look at the last entry in this post and see if the indications are close to yours.
http://townhall-talk.edmunds.com/direct/view/.f1fbb21/53#MSG53
https://chevroletforum.com/forum/equ...removal-61765/
Old May 17th, 2015, 4:23 PM
  #12
tracy28's Avatar
Default key stuck no power
went to start car put key in no power tried to pull key out its stuck
Old May 17th, 2015, 8:15 PM
  #13
sledge.impy's Avatar
Get it some power.
Old January 1st, 2020, 2:17 PM
  #14
Wes Lewis's Avatar
Originally Posted by Jimmie Meadows
I have a 2009 Equinox FWD LS. I put the key in the ignition and it turns to the on position, does not start. No clicks, no dash lights. The only dash light recently when it was working was reminding me that my oil was at 5% and a low tire warning (censor went out a few months ago and have a normal valve stem now). It won't turn all the way to the off position and the key is stuck. The steering wheel turns fully in both directions. The shifter is free of coins.
My moms has the same problem. She turned it off and now it won’t do anything. Key is stuck. No lights but the battery is new and fully charged. I replaced the battery in the keyless because I thought maybe it was a security issue.
Old December 1st, 2022, 2:46 PM
  #15
Dalton lee's Avatar
Default Same problem
how did you fix the problem
Old December 6th, 2023, 9:28 PM
  #16
Player One's Avatar
Check and relocate the PCM ground. Just in case it's located behind the intake on the block
otacon28
October 29th, 2014 5:54 PM
SabrToothSqrl
March 23rd, 2014 5:45 PM
BigblackHo3
April 5th, 2013 8:54 AM
otacon28
March 11th, 2007 1:32 AM
Sandman
February 28th, 2006 12:25 PM
Quick Reply: Key stuck, no power.
