Loud knocking sounds come from top of motoor all is tight
Ok so all of a sudden i have a loud loud tapping knocking noise seems to come from topend of the motor took walve cover off all is tight nothing looks bad its a side mount motor coming from side by fire wall took intake off not to dirty inside was a light noise then one day wow but when i shut the motor off u can hear it continue to knock as a part slows down to a stop never heard this before in a vehical normally when u shut off the motor the noise gone but this stays for a few seconds thought was a valve lifter priblem but all is tight sounds really bad hope someone can help and the part were it still knocks after motor is off its a knock for sure thanks
Same problem
In the last week the same sound has happened to my 2010 Equinox. The heat is also not working that well so I think the two issues might be connected. Could it be the heat blender? Although I don’t really know what that is, from reading other forums it seems to be a problem part on older Equinoxes. The knocking sounds like it is coming from behind the glove box and it does it even when the car is shut off. The other day it did it when the cat was cold and parked in the garage. It just started doing it and then it would stop. Any ideas of the cause and fix would be really appreciated. Thanks
