outside air temp
It is showing Day, Date and Time on the Chevy My Link screen. Is there a fuse just for the outside air temp. I had a small fender bender on the right side that is why the replaced the broken temp sensor. Could it be the wrong ambient temp sensor? Thanks for your reply.
Thank you, I tried to do a new set up but did not work . Still no temp reading on screen. I also can not seem to find out how to change the temp reading on the auto ac from cel. to far.
The outside Temp is finally fixed, also the temp settings. Chevrolet had to do a Harness repair after they had to R & R bumper and R & R battery fuse block under the hood to gain access and repair the Harness. It was covered by the Warranty. Thank you.
