Chevrolet Equinox
Platform: Theta
07 Tachometer erratic
Old Nov 10, 2014 | 3:32 PM
jerryotis's Avatar
Default 07 Tachometer erratic
My tach has a mind of it's own! Reads all over the place, even clear off the scale. If I disconnect the battery for a few minutes, it will work fine for an indefinite amount of time and then suddenly act up again. Any thoughts?
Old Nov 18, 2014 | 9:21 AM
ThatChevyGuy's Avatar
is it a v6 or a 4-cylinder.
has the tach ever been replaced or removed for any reason?
Have you ever changed the distributor? If you are using a magneto distributor, you must have supression core spark plug wires, silly i know.
Old Nov 18, 2014 | 6:36 PM
ruley73's Avatar
I believe it's been over 10 years since any vehicle rolled off the assembly line with a working distributor (Dodge Ram truck 5.9L); 20 years ago if you narrow it down to the Chevy 60-degree V6 (2.8/3.1/3.4L/3100/3400). The 3400 V6 was the only engine used in the 2007 Equinox and it has a distributorless ignition system like virtually all other modern vehicles.
Old Nov 18, 2014 | 7:52 PM
mswerb's Avatar
Try pulling the fuse for the gauge cluster. I have an 07 as well and my fuel gauge went nuts a while back. Pulling the fuse seemed to work for me.
Old Nov 18, 2014 | 8:41 PM
burhead1's Avatar
Will most likely need to replace the motor in the cluster for the tach, you can by them on line. They come as a kit with motors(servos) and replacement led lights.
Old Nov 18, 2014 | 10:25 PM
Lol didn't think about that one. I still drive an old chevy with one. Lol
dmoore
Dec 7, 2011 9:02 PM
fdxdoeboy
Nov 16, 2007 11:12 PM
shulamite
Nov 12, 2007 3:41 AM
Rivernut
Nov 1, 2007 7:14 AM
96beretta142k
Sep 27, 2006 3:20 PM
