Chevrolet Equinox
Platform: Theta
2005 AC/Heat blend door
Old Jul 14, 2017 | 5:03 PM
kaynarde1's Avatar
Default 2005 AC/Heat blend door
The AC on my 2005 Chevy equinox is putting out very little cool.
The compressor is good and cycling properly.
The Freon level is correct.
The cabin filter has been removed since it was dirty.
The actuator is not making any clicking sound so I assume it is working properly.
The HVAC fuse is good. I pulled it with the the car on and AC working for 10 seconds to see if it needed to readjust itself...and it did not realign, so I will assume that it has not gotten out of sync.
The passenger side cools slightly better than the driver side. Maybe this is because the compressor is on the passenger side and therefore cools better than the driver side.
I am concerned that the issue may be a broken Blend Door.
Maybe heat is coming through the vent at the same time that the AC is blowing.
Maybe I should remove the glove box and try to see if the nipple on the blend door is broke where the actuator connects/inserts.
I need help.
Kay
Old Jul 14, 2017 | 5:45 PM
ruley73's Avatar
Does the A/C get warmer when the engine is idling, but cools fine when not stopped or if the engine is above idle? If so, the scroll valve in your compressor may need to be replaced. This is a common issue that only affects the 2005 Equinox. Watch the video linked below to learn more. The 2006 and newer models have an A/C compressor with a newer design that eliminated the problematic scroll valve.
