Chevrolet Equinox
Platform: Theta
2005 Code help!
Old Apr 18, 2012 | 9:26 AM
whiskeywarden's Avatar
Default 2005 Code help!
I took my 2005 Equinox LT in for an inspection and it failed for the following codes:
U31D5
C3000 = x4
PODD6
P17CE
P12CF
P0100 = x2
When I put the OBD tool on it it shows a P0128 code.
The temp gauge does not fluctuate and runs in the normal range. Heat and AC work fine. Other than the engine light everything works as it should.
I changed the thermostat (195 deg) and flushed the system. I also changed the Mas Air Flow Sensor.
I am about the change the ECT sensor to see if that helps. When I changed the Thermostat the eng light did go off for approx 100 miles.
Anyone have these issues and/or resolutions?
Old Jun 6, 2012 | 8:51 AM
Solved!
Changed the ECT sensor ($10) and engine light went out and it passed inspection without problems.
Hawkeye13
Cobalt
Sep 10, 2013 9:32 AM
Donthaveone
Aug 27, 2013 9:45 PM
Vinna
Nov 12, 2012 8:51 AM
iss
Sep 2, 2009 9:48 PM
JRT600
19
Jun 4, 2009 11:44 AM
