2005 Equinox coolant into reservoir when accelerating
![Question](https://chevroletforum.com/forum/images/icons/icon5.gif)
I purchased a 2005 Equinox with 118K miles on it 2 days ago. Everything was fine on the test drive. Yesterday, I noticed a gurgling noise while in 'Park' after tapping the accelerator. I checked under the hood while my wife pressed the accelerator and coolant was sloshing into the reservoir every time the accelerator was pressed. I drove it for an hour prior and after and the temp never crept above normal operating range. Any idea what it might be? I am supposed to be driving from NM to FL in 2 days.
If you have had the coolant replaced recently, the cooling system may need to be properly bled.
Aside from that, everything you are experiencing is normal. Unless the "gurgling" is really loud, I wouldn't worry about it. I have been able to hear coolant flowing through the heater core on every vehicle I have ever owned. In every instance I was only able to hear it with the engine running, radio off, and HVAC fan off. In other words, it is only audible under the ideal conditions when the cabin is really quiet.
The coolant reservoir is not simply an overflow tank. Coolant constantly flows through it. When you rev up the engine the water pump propels the coolant through the engine faster. The coolant "sloshing" into the reservoir while revving the engine is normal.
otto11
December 28th, 2013 11:53 AM
Delbert
March 29th, 2011 10:59 PM
