Chevrolet Equinox
Platform: Theta
2005 Equinox engine swap
Old Nov 28, 2014 | 6:20 PM
hazeyacres's Avatar
Default 2005 Equinox engine swap
A friend of mine needs to replace the motor in her 2005 equinox. She doesn't have a lot of money so she asked me to help her find a used motor. My question is, what years can she put in this and will any 3.4 motor go in it? Just things I need to know before I find her one. (A mechanic will be checking whatever motor she buys and installing. I am just trying to help find one) Thanks in advance for any help. <!--POLLS--> <!--FILES--> <!--SIGNATURE-->
Old Nov 29, 2014 | 8:06 AM
tomwalt's Avatar
If you are paying a mechanic to do the swap (this is just my 2 cents); the 2005 was a troubled model year for the nox and you may be gambling with quite a bit of good money - what else will they find after a used engine is installed.
Junk yards have a way to convert the various comparable/compatible engines.
Key point - keep your existing computers/intake manifold/fuel injector ect. Even a compatible engine may not be 'computer compatible' and then you'll be stuck with going to Chevy to get it fixed and that will be big $$.
I've had good luck with Jasper engines/xmissions - but I only did hobby cars.
Old Nov 29, 2014 | 1:01 PM
ruley73's Avatar
What's wrong with it that warrants replacing the engine? To answer your question, only a 3.4L/3400 from a 2005-2006 Equinox/Torrent would be a direct swap. The 3400 from a 2007-2009 Equinox/Torrent apparently has some changes/differences and would not be a direct swap, but may be able to be used if you can find the differences and make it work.
A 3400 from any other GM model will not work.
Old Mar 10, 2020 | 1:22 AM
Tony Lanier's Avatar
3400 engine block the same as a 3400 engine block of the 05 equinox I want to know are the engine blocks the same
Old Mar 10, 2020 | 2:25 AM
ruley73's Avatar
Clarify the question. I'm unsure what block you want to compare to a 2005 Equinox 3400.
Old Jan 8, 2021 | 10:03 PM
Tina whatley's Avatar
Can you direct swap engines from a 05 equinox Lt 2 wheel drive over to a 05 equinox Lt AWD?
Old Jan 9, 2021 | 12:21 PM
ruley73's Avatar
Yes, it's a direct swap. AWD vs FWD doesn't make a difference with the engine.
jmjm911
Oct 15, 2021 2:27 PM
MVILLA1368
Dec 15, 2014 7:36 PM
Volare
Sep 3, 2014 8:28 AM
PARTING05EQUINOX
Jun 27, 2013 7:22 PM
lbcepe
Jan 9, 2012 6:53 AM
