Chevrolet Equinox
Platform: Theta
2007 Equinox Heater problem
Old Feb 16, 2020 | 9:38 PM
phil_hert's Avatar
Default 2007 Equinox Heater problem
Have a 2007 Chevy Equinox
Heater / Air were working fine.
Smelled antifreeze when turning on heat – and saw small amt of fluids on garage floor.
Took to shop – they found water pump leaking – replaced.
Heater now not working properly. Feel heat while sitting and going slow – but when travelling to highway speed – blows cool air.
Still smelled antifreeze – further checking – replaced bad heater core.
Still no heat.
Shop cleaned out hoses, etc and now replaced radiator.
Still no heat at higher speeds.
Shop seems stumped. Thoughts?
Old Feb 16, 2020 | 10:52 PM
are you getting a p0128 code?
Old Feb 16, 2020 | 10:57 PM
Irish_alley's Avatar
I'm here for the party
could the blender motor/door be stuck? not sure about the equinox but i know the early 2000's trucks had this issue of the heater core was leaking. it would drip a small amount around the blender door and then dry up and cause it to be stuck in one position or another. also if the coolant was just about topped off it would also blow cooler air.
Old Feb 18, 2020 | 8:32 PM
phil_hert's Avatar
no codes show
Old Feb 18, 2020 | 8:34 PM
phil_hert's Avatar
how would I know if the blender motor/door was stuck?
Old Feb 18, 2020 | 8:37 PM
can you hear it move?
Old Feb 18, 2020 | 8:40 PM
phil_hert's Avatar
sorry, ignorant here, will it move when the temp control is moved from cold to hot and back etc
Old Feb 18, 2020 | 10:48 PM
it should move. you should hear it around the passengers side floor board. might "clunk" might just slowly wind into position.
Old Feb 19, 2020 | 12:23 AM
ruley73's Avatar
Make sure the cooling system has been sufficiently bled. The 3.4L in the Equinox is a challenge to bleed. I highly recommend parking the vehicle on an incline to make the bleeder screw the highest point in the cooling system. A shop should know better, but this is easy enough to try yourself. All you need is a 7mm socket for the bleeder screw - which is located above the water pump housing.
Chevy_Nox
Jan 19, 2022 9:31 PM
shawnaschafer
Jan 24, 2020 10:04 PM
Justin Nelson
Oct 20, 2019 6:45 PM
Mommyrocket84
Nov 11, 2014 1:49 PM
odigidy
Feb 7, 2007 12:06 AM
