Chevrolet Equinox
Platform: Theta
2008 Oil consumption. Where does it go?
Old Sep 9, 2021 | 8:13 PM
David DSa's Avatar
Default 2008 Oil consumption. Where does it go?
I have a 2008 equinox 3.4L bought 4 years ago at 142k kms. I dutifully replace the oil every 6k with synthetic oil, (pennzoil high mileage)I have noticed that I have to top up quite a bit during the course of 6k.~ 3L. I also use gum out high mileage fuel system cleaner before each oil change.
I’ve noticed No black smoke, no sluggish performance and good fuel consumption. 12l -100 kms mixed driving.
Where does this oil go?
Old Sep 9, 2021 | 8:52 PM
ruley73's Avatar
You must have a leak. These 3.4L engines don't commonly burn/consume oil.
Old Sep 9, 2021 | 10:14 PM
what do the plugs look like. any ash deposits?
Old Sep 10, 2021 | 12:30 PM
David DSa's Avatar
Ruley73: In the 2 years that I have owned the car not a drop on the driveway
tech2: I changed the plugs when I bought the car at 140k and they were clean. haven’t checked after. Car starts at the first crank- winter and summer.
Old Sep 10, 2021 | 3:00 PM
ruley73's Avatar
A gummed up PCV valve could also cause excessive oil consumption. The PCV valve isn't serviceable and requires replacing the left/front valve cover. You can try disconnecting the hose that goes to the PCV valve and spraying some brake cleaner into it to free it up. As long as you don't use an excessive amount of brake cleaner, it won't hurt anything and changing the oil afterwards isn't required. I'd also perform a visual inspection of the engine if you haven't already done so. Our Equinox has a slow leak, but also never leaves any oil on the garage floor. I usually don't need to add oil between oil changes.
Old Oct 4, 2021 | 6:23 PM
David DSa's Avatar
I read a thread on redflagdeals this afternoon that the difference between the top marker and the bottom marker of the dipstick is 500-1000 ml. Is this true for the equinox. I may have to reevaluate the high oil consumption theory.
P0well
Apr 16, 2023 4:34 PM
bananas
Oct 24, 2022 2:24 AM
JAMBUS
15
Jan 23, 2017 4:32 PM
Son_Of_Thunder
Jan 5, 2012 8:20 PM
pacman13
Nov 18, 2009 10:02 PM
