Chevrolet Equinox
Platform: Theta
2010 Chevy Equinox transfer case fluid
Old Dec 13, 2019 | 3:19 AM
getpusschevy's Avatar
Default 2010 Chevy Equinox transfer case fluid
Okay guys what goes in the transfer case 2010 Chevy Equinox all wheel drive do I put gear oil in it or is there something different was told to use 75 90 synthetic gear oil
Old Dec 14, 2019 | 10:51 AM
ruley73's Avatar
Your owners manual specifies that p/n 88861950 should be used for transfer case fluid. There might be an aftermarket fluid available that may work, but I couldn't find one with a quick Google search. The little bit I did read seemed to indicate that it actually is a special fluid. The 75W-90 synthetic fluid seems to be OK for 2013+ models, but the 2010-2012 Equinox/Terrain uses different fluid in the transfer case.
Old Dec 16, 2019 | 11:49 AM
apgillespie's Avatar
I show that transfer case as a GETRAG 760 which has a 0.8 liter capacity of SL136 lubricant you can call your chevy parts dept but it seems to be a synthetic axel lubricant SAE 75W/90
Old Dec 16, 2019 | 9:23 PM
oilcanhenry's Avatar
Use full synthetic synchromesh transmission and transfer case fluid. The days of using 80-90 axle fluid are long gone in modern vehicles.
ACDelco 10-4006 Synchromesh Manual Transmission Fluid is what you want. Valvoline and Royal Purple have similar lubricants too.
baskervi1
Oct 29, 2015 8:42 AM
desert chevy
Feb 12, 2010 9:16 PM
dkbrucedvm
Mar 31, 2007 7:10 PM
LAVABOY
May 1, 2006 1:23 PM
gtntn
May 1, 2006 12:56 PM
