2011 Equinox battery replacement
Need to replace the battery in this vehicle. Removed the computer and am now trying to figure out how the bracket securing the battery is removed. I removed one screw but can't figure out how the end at the frame of the vehicle is secured. Do I need to remove the plastic molding to get the bracket off?
Also, do I need to purchase a "memory saver" to preserve the electronic factory settings before I remove the positive cable?
Thank you very much for your assistance!
Battery replaced-
Done, easy once the molding was popped off. Removed battery and all settings and electronic components were still perfect.
