Chevrolet Equinox
Platform: Theta
2011 Equinox loss of power while driving
Old Feb 4, 2022 | 11:57 AM
cuttings67's Avatar
Default 2011 Equinox loss of power while driving
My 2011 Equinox will suddenly act as if it is running out of gas while driving. This happens at variable speeds and is very intermittent. Sometimes it will stall but it will start right back up. I have been to three different mechanics who have performed troubleshooting and they could not come up with a cause. I have done the following work trying to fix this issue: New spark plugs, new air filter, new VVT sensors, new upsteam and downstream O2 sensors (there was a code showing for these), new Mass Air Flow sensor, new throttle body, Injector cleaning (done by a dealer). My fuel pressure is 58 psi (key on engine not running). Fuel pressure is 58 psi while running and will drop to 40 psi. I don't know what the fuel flow is. There are no codes showing. Has this condition happened to anyone else? I would appreciate any and all suggestions for repair of my Equinox.
Old Jun 22, 2022 | 9:15 PM
josh1234's Avatar
Default This is for the people who having problem with engine power reduced and traction on
Accelerater pedal 90% of the time sometimes throttle body. U could have problem with wiring too I just fixed 2013 equinox one of the gas pedal electric wires was shorted to ground I run new line from gas pedal to ecu look at diagram
Old Sep 22, 2024 | 8:08 AM
Unhappycamper77's Avatar
Default Same issue on 2012
My son is having the exact same problems with his. Did you ever find a resolution????
petry
Apr 29, 2022 1:24 AM
johnhop
Feb 23, 2018 5:17 PM
nabilkawa
May 9, 2017 5:44 AM
nabilkawa
May 9, 2017 5:41 AM
laman
Mar 9, 2015 10:50 AM
