Chevrolet Equinox
Platform: Theta
2011 Equinox oil sensor
Old Aug 17, 2012 | 12:14 PM
flutemaker's Avatar
Default 2011 Equinox oil sensor
I have a couple of questions about oil pressure on a 4 cy engin. that being at what point (pressure) does the indicator come on? Does this sensor detect oil level? If the sensor is for pressure only then is there a minimum amount of oil in the crankcase at which the sensor will come?
How much oil should a 4 cylinder consume between oil changes? I also understand that the engine oil is also used in the valve train.
Any insight welcome.
Old Aug 20, 2012 | 1:08 PM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> flutemaker,
Would you please provide the last 8-digits of your VIN, so I can look into this further for you?
Louis
GM Customer Service
john1231989
May 4, 2017 12:21 PM
janno
Jun 15, 2011 2:14 PM
Rusty
Jan 8, 2011 9:15 AM
bowtiedriver2
Dec 4, 2010 4:47 PM
mocaman
Jul 21, 2010 7:29 PM
