Chevrolet Equinox
Platform: Theta
2014 Equinox rear power liftgate does not work.
Old Mar 20, 2019 | 1:40 PM
Bryce Alford's Avatar
Default 2014 Equinox rear power liftgate does not work.
It will not open with either the button on the inside, key fob or the button by the rear camera. The fuse is good. Will replacing the push button switch on the liftgate fix it? thanks.
Old Mar 20, 2019 | 7:48 PM
most likely not. does it try to lift at all and fail or no response?
Old Mar 21, 2019 | 8:18 AM
It does not try to lift at all from all 3 sources, no clicks, vibrations, nothing.
Any idea of what the fix might be if replacing the switch on the liftgate might not do it?
Old Mar 21, 2019 | 8:32 AM
the 2 buttons and the fob are only input requests to a module that commands the door to open. its unlikely that each separate input failed at the same time.
hard to say what is wrong without scan tool data and opening up the system to inspect.
Old Mar 21, 2019 | 8:39 AM
Ok and I did hookup my ODBII and found no current fault codes nor anything in the history. My device is pretty basic so I might need a more advanced/expensive reader...........maybe a dealer or auto repair facility that can read more data and/or dive deeper into the vehicle's computer?
Old Mar 21, 2019 | 6:38 PM
ruley73's Avatar
You'll need a better code reader. Most cheap ones only retrieve powertrain (Pxxxx) codes. Even then, it's possible that a bad latch won't throw any troublecodes.
Unless you have a wiring fault somewhere (check harness going to liftgate), I'm thinking that you need a new liftgate latch/actuator assembly (AC Delco p/n 84243380 w/power liftgate; p/n 13584872 w/o power liftgate). Some places have this part listed as a trunk latch or trunk lock actuator.
Old Mar 21, 2019 | 7:42 PM
everything is controlled by a liftgate module...all the switch input data could be viewed with a scan tool that can access body systems. the remote operation is bussed to the liftgate module via a communication line
Old Mar 22, 2019 | 8:34 AM
Ok, thanks for the replies. I will try to locate a better reader to see if I can retrieve any error codes. Any idea where this liftgate module is at?
Old Mar 22, 2019 | 12:03 PM
ruley73's Avatar
I'm not 100% sure, but I'm betting that it's probably the electronic part of the latch; not a separate item.
Old Mar 22, 2019 | 1:36 PM
Ok, I have had my vehicle read by a good code reader and it only found some old fault codes related to my sunroof. All codes were cleared and the liftgate will still not operate from either 3 options.....button inside, key fob or button on the liftgate. I did find a replacement for the module online, around $200 and I can replace that myself, however the auto repair shop that read my vehicle said I would still have to have a dealership involved as they have to program the new module to my car? Is that correct?
