Chevrolet Equinox
Platform: Theta
2015 Equinox p0411 p0412
Old Mar 9, 2020 | 6:47 PM
Kevin C's Avatar
Default 2015 Equinox p0411 p0412
I have a 2015 equinox and I have been receiving the P0411 (that advanced auto gave me). Today I got a blue tooth OBDII tool and it is also giving me P0412 which is "secondary air injection system Switching Valve "A" Circuit" Steps I have taken so far have been removing air pump and hooking power up to it and it works fine. I tested 2 relays and a fuse in the fuse box and they seemed good. I removed the check valves (they are pretty carboned up) I cleaned them the best I could. I also did the seafoam into the throttle body. I guess my main question is where should I go from here? Is the switching valve the same as the air injection check valves, or is there some other solenoid or electrical thing i need to be looking at? I dont want to spend $270 on 2 check valves if it is just a wiring harness or solenoid issue. On a side note when I change the oil I am missing 2-3 quarts of oil. Not sure if that is related to anything or not.
Thanks for the help
mrlee75
Jun 17, 2019 11:30 AM
Blackjack21Larry
Jan 5, 2017 12:07 PM
Betsy Strayer
May 26, 2016 7:54 PM
holguiny13
Mar 17, 2016 7:19 PM
allboth
May 28, 2015 2:19 PM
