2017 Equinox AWD LS knocking noise when turning
About a month ago my 2017 equinox AWD LS started making a knocking noise when I am turning left and right during acceleration. It sounds like I’m driving over reflectors is the best way to describe it and seems to be coming from the rear of the car . I have had a new rear axle differential put in , new CV axle and new bearings I believe and the noise is still there. We’ve taken it to 2 different mechanics and they aren’t sure what the issue is . Has anyone else experienced this . I’m going to try and attach a video I took of the noise
did you ever find the problem? Currently having this issue
could be a lot of things.
worn CV joints, loose strut mounts, lose stabilizer arm links, ...
Need to hook your peepers on down beneath
I am experiencing the same issue- did you ever resolve it? Making a studdering when turning at lower speeds. I read that if you pull the AWD fuse the problem will go away so it must be related to the AWD system.
Equinoxowner
May 24th, 2024 3:23 PM
Stiffman311
October 6th, 2022 7:37 AM
