Chevrolet Equinox
Platform: Theta
2017 Equinox AWD LS knocking noise when turning
Old Sep 23, 2022 | 5:36 PM
bmselfx3's Avatar
Default 2017 Equinox AWD LS knocking noise when turning
About a month ago my 2017 equinox AWD LS started making a knocking noise when I am turning left and right during acceleration. It sounds like I’m driving over reflectors is the best way to describe it and seems to be coming from the rear of the car . I have had a new rear axle differential put in , new CV axle and new bearings I believe and the noise is still there. We’ve taken it to 2 different mechanics and they aren’t sure what the issue is . Has anyone else experienced this . I’m going to try and attach a video I took of the noise
Old Sep 21, 2023 | 9:30 AM
2015equi's Avatar
Default Find a fix?
did you ever find the problem? Currently having this issue
Old Sep 21, 2023 | 1:03 PM
could be a lot of things.
worn CV joints, loose strut mounts, lose stabilizer arm links, ...
Need to hook your peepers on down beneath
Old Feb 3, 2024 | 11:10 AM
Dave_Kl's Avatar
Default Same Problem
I am experiencing the same issue- did you ever resolve it? Making a studdering when turning at lower speeds. I read that if you pull the AWD fuse the problem will go away so it must be related to the AWD system.
Old Feb 3, 2024 | 6:57 PM
so what happened when you tried it?
How many miles does it have? Have you been maintaining the AWD system regularly?
Fullsend
Feb 27, 2025 9:26 PM
Equinoxowner
May 24, 2024 3:23 PM
Stiffman311
Oct 6, 2022 7:37 AM
KHALID
Feb 9, 2022 7:01 AM
hking44
Sep 20, 2019 6:39 PM
