3.8 Liter fit in a 2005 LS?
Hello all,
I just aquired a 2005 equinox and am wondering if I can swap out the engine for a 3.8 liter so that it can be tuned. Any ideas?
Long answer: The motor may physically fit in the engine compartment, but one would need to perform extensive modifications to make it fit correctly. The mounting setup for the 3.4L/3400 is completely different than the 3.8L. If I were going to swap in any engine, it would be either the DOHC 3.6L V6 (which was optional in 2008-2009 Equinox) or the 3900 V6 (optional in G6, Impala, and later Lucerne) which shares the same basic design as the 3400. In stock form the Series II/III 3800 (200 HP, 220 Ft-Lbs Torque) doesn't have much more power than the 3400 (185 HP, 210 Ft-Lbs torque) anyways, so IMO it would not be worth the hassle. The 3.8L in N/A form doesn't have much more potential. The supercharged variants of the 3800 are a whole different story though.
Good4JG (July 10th, 2021)
Short answer: No
Thank you!
the next gen that used the 2.4 ecotec probably could be easily turbocharged. for less than 2g, zzp has direct fit t turbo for the 2.2 and 2.4 ecotec used in cobalts. the nox verion is DI so it may produce over the claimed 260 wheel hp of the balts.
Short answer: No
The 3.6 L engine is extremely unreliable compared to the 3800 series 2. in which the only problem I ever had was probably a leaky valve cover gasket. as for the 3.6 it constantly has timing chain issues it will find any reason for it run rough or misfire or have a rough idle… a 3.8 rarely had any issues so I would lose a little horsepower for a better engine…
id love to find someone that could mate the 3800 series 2 to the six speed automatic in my torrent GXP ( maybe even get tuned to put out the same horsepower as the 3.6 ) the GM 3.8 was damn near bulletproof the 3.6 just needs to to be shot
lbcepe
January 9th, 2012 6:53 AM
