Chevrolet Equinox
Platform: Theta
can i pour seafoam in the g/f vacuum lines?
Old Mar 15, 2012 | 10:17 PM
Mille Racer 69's Avatar
Default can i pour seafoam in the g/f vacuum lines?
So she's got an equinox and I am going to go through it
Giving it a tune up. I pour seafoam down my vacuum line via the pcv
Valve to get all the Carbon deposits and other crap out.
Can I do this with the equinox as well?
I just wanna make sure there is nothing special in there
that could be damaged.
Thanks!
Old Mar 15, 2012 | 10:51 PM
ruley73's Avatar
The PCV valve itself is not replaceable. It is built into the front rocker arm cover. As a result, it can only be replaced if you replace the rocker arm cover.
2005-2009 3.4L PCV-valve-replacement.pdf
There is no easy way to inject the Seafoam on this engine because the engine uses a sealed intake system. The only option you have is to buy the Seafoam spray with the small tube. Click here for more info.
This engine uses a throttle by wire setup. There is no throttle cable - it is run electronically. You can still clean the carbon from around the throttle plate, but you do need to be careful.
Elton T
Jul 6, 2013 1:20 AM
gdavies07
Nov 7, 2011 11:47 PM
wblack
Oct 12, 2007 4:11 PM
jffgin
Sep 16, 2007 5:42 PM
jffgin
Sep 8, 2007 3:23 PM
