Chevrolet Equinox
Platform: Theta
equinox 2007 headlights out
Old Dec 29, 2011 | 9:18 PM
rjmtool's Avatar
Default equinox 2007 headlights out
2007 equniox low beam head lights just stopped working but when i pushed the high beam lever the high beams
came on but only if i held it low beams would still not work if i let go of the lever when i got home and restarted the car the lights worked like they should 38000 miles
i need some help if anybody knows a fix or that the problem might be
Old Dec 29, 2011 | 10:23 PM
was the system in the auto lamp control positon or manually on?
Old Dec 30, 2011 | 5:31 PM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> It may be time to replace your headlights. Low beams and high beams are usually a different bulb or a different filament in the headlight. The low beams tend to burn out first, because they are used more. This is just a suggestion to consider, not a diagnosis. You may want to consider taking the vehicle in for an inspection.
Please keep us posted.
Have a great day!
Louis
GM Customer Service
Old Dec 31, 2011 | 10:34 AM
rjmtool's Avatar
i have already replaced them twice, lights were in auto mode
Old Dec 31, 2011 | 11:49 AM
Are the low beams out in both daytime running light mode and manual low beam operation or both?
to check the dtl operation make sure its in bright daylight, the car is running, in drive with the e-brake off.
Old Dec 31, 2011 | 1:05 PM
rjmtool's Avatar
the headlights seem to work ok after i restarted the car but something caused this, i do not know if this is related but sometimes the wiper lever
does not work unless i push it toward the dashboard
Old Jan 1, 2012 | 2:13 PM
are the wiper and headlamp controls all part of one multifunction switch?
David_lee1993
Nov 1, 2012 11:06 PM
AcousticHoney
18
May 30, 2009 5:46 PM
mentalmom
Nov 26, 2008 6:05 PM
